Postive to ground or Negitive
LarryOn
10-13-2004 19:04:33
I have just started to restore a 1952 TEA. 12 volt system - Lucas coil with SW marked by one post and I believe is marked CE by the other post. Is the SW side the neg and the CE side the positive . This would maked the system postive to earth(grd). Want to make sure Thanks
txblu
10-15-2004 09:17:08
 Re: Postive to ground or Negitive in reply to LarryOn, 10-13-2004 19:04:33
If it is a single circuit switch, you don't care as there is only one input, one output, and one piece of metal connecting the two. Nothing magic inside; metal to metal.
If it is a combination switch that serves multiple functions, then you need to know which terminal is the "feed". That can be done with an ohmmeter and a little time, seeing which terminal connects to all outputs depending on what position the switch is in.
I think all 6 volt ckts are pos gnd and 12's are neg.
Mark
Jim W
10-14-2004 06:18:30
SW means switch (as in ignition), and the other is CB which stands for contact breaker i.e. points. They were originally positive ground although many have been reversed by now.
Jim
