retro fit distributor
glen (ontario)
10-13-2004 15:03:26
Today at work I saw a retro fit distributor on an old transport mule the kind used at airports they were rebuilding the engin and the distributor was worn and parts were not available so they went with the retro fit .I asked what they would fit on and he told me they would fit on almost anything has anybody seen these on a TEA or on any other old tractor .by the way the reason I am asking is because my distributor advance return springs are finished and not avaiable
John (UK)
10-15-2004 13:31:15
 Re: retro fit distributor in reply to glen (ontario), 10-13-2004 15:03:26
There is a distributor that will fit a TEA and its suppied by Bare and Co of Australia, they now have an outlet in Cali I think. There was also a distributor from a Land Rover that would fit as well, but I don't have anymore info on that one.
Bill In Markham
10-15-2004 04:29:24
Glen I have to ask this, what year is your TEA, I have a I think a 1952 and I yet to see any springs in the distributor....better still what make is your distributor.
Thx Bill
glen ontario
10-15-2004 13:42:26
 Re: retro fit distributor in reply to Bill In Markham, 10-15-2004 04:29:24
Bill I have a 54 tea with a lucas distributor John is right all the works are under that plate which requires oiling manualy when these run dry they will wear the brase bushing and bearing and cause the shaft to woobel and cause points to misfire I have a prime example of it
John (UK)
10-15-2004 13:22:26
You will have springs in your distributor, they are buried right down at the bottom under the plate that carries the points. They are used on the weights that advance and retard the timing.
Jerry/MT
10-13-2004 18:40:33
There is an outfit in Portland, OR who may be able to help you. Call Mark Nikolay at 800-869-7301, [email protected], or www.philbingroup.com .
