TE-20
Don
03-31-2000 12:53:00
I have a 1948 TE-20 that's in excellent condition. However, after having to replace a starter, I'm concerned about the availability/cost of replacement parts should anything else go wrong so I'm considering selling it. Any suggestions or opinions regarding the availability of parts for this tractor. Besides the parts issue; the tractor is perfect size and condition for me.
rockhead
04-01-2000 08:29:59
 Re: TE-20 in reply to Don, 03-31-2000 12:53:00
Don-
Don, I don't know if you're in the UK or the US,
but in the US, the Massey-Ferguson dealers
carry a full line of parts way back to the Massey-Harris days (earlier than Ferguson). Heins MF in Valatie, NY has been good to me
and does mail order. The site for this discussion board (YT) also sells
parts, as does Central Tractor. Not sure about
differences between TE20 and TO20.
Jerry Mientkiewicz
04-03-2000 19:05:03
 Re: Re: TE-20 in reply to rockhead, 04-01-2000 08:29:59
I am told that the availability is better from Canadian sources are better for the TE-20 than here in the USA (TEA-20 with standard Gas Engine)as opposed to the Continental Gas Engine. TO had the Continental Gas, if I recall, if not, enough of you are out there to correct me. The Standard is a larger motor, some oddball parts, still a lot of good sources...Hang on to that iron, good stuff lasts and lasts. Also, if you ever do a split on that tractor, the flywheel can be changed and a standard Continental starter can be used. Central Tractor has a fair selection of parts, ditto the MF dealers.
Randy Tucker
04-24-2000 18:46:52
 Re: Re: Re: TE-20 in reply to Jerry Mientkiewicz, 04-03-2000 19:05:03
Parts for the TE-20 are easily available up there from Selmac Sales in Stony Plain, Alberta, Canada. Their number is 780-963-2251. I have a TE-23 which is basically the same and have had no problem getting parts.
