Ignition system with ballast resistor........
Bill In Markham
10-11-2004 04:33:06
Hi All I about to put my Tea back together, I've seen on the forum diagrams with a diode (why the diode) and systems with two wires off the altenator (I have one). Can I improve on what I have? On my Tea the starter engages from the gear shift, the ballast resistor inline between the igition and the coil and is a negative ground system.
Thanks Bill
Bill In Markham
10-15-2004 02:22:50
 Re: Ignition system with ballast resistor........ in reply to Bill In Markham, 10-11-2004 04:33:06
Don The problem is I don't have the diode inline from the altenator and the tractor shuts down.
Don from Co.
10-13-2004 10:18:32
I understand that without the diode the engine will keep running after you shut it off.
txblu
10-11-2004 06:11:24
No problem with the shifter start or ballast resistor in series with coil.
The alt has one big output to the batt (for recharging), one small wire to the batt via the ign switch (for runnin the alt) and one small wire to the idiot light so that when it's puttin out, the light's out and when it's not, it burns....like when you turn the ign key on and the engine is off....it burns. Battery voltage is on the otherside of the idiot light.
