What's TO30 worth that needs a engine and what's t
Dennis Williams
10-09-2004 06:10:02
I have yet to see the tractor, but and wondding what it's worth? The add states that it's in good shape so what do you guys think it's worth? Also what is a good used block going for? Thanks Den
Dennis Williams
10-14-2004 04:06:09
 Re: What's TO30 worth that needs a engine and what in reply to Dennis Williams, 10-09-2004 06:10:02
I went and looked at the tractor and the block is shot. The rest of the tractor looks ok it's been sitting a few years. He said the junk yard would give him $750 for her. I thought it was worth $250 ish. THe best thing on the tractor was the rear tires. Den
Paul in Ms
10-09-2004 07:17:38
The to-30 would have to have good tires,paint and tin for it to worth $500. A good block can run from $400 to $600. What is wrong with the original block. If was cracked it can be repaired.
Dennis Williams
10-10-2004 04:51:18
 Re: What's TO30 worth that needs a engine and what in reply to Paul in Ms, 10-09-2004 07:17:38
Paul, there a hole in the side of the block from a thrown rod. I don't know how bad the rest of the engine is. Den
Paul in Ms
10-11-2004 04:56:39
 Re: What's TO30 worth that needs a engine and what in reply to Dennis Williams, 10-10-2004 04:51:18
Without tearing the engine down you won't know how much damage there is inside the engine. The crank is the main concern. If the damage from the rod is not to bad it can be turned down. A whole engine will cost &1000 and up. The key is to buy it cheap and how much your time is worth.
Jim W
10-10-2004 05:52:33
You're buying the back half of a tractor in unknown condition - you can't check out the hydraulics or transmission. It needs to be cheap.
Jim
