pto lifting weight
John-AZ
10-08-2004 02:17:44
Hi everyone I am a newbie. I have had my to-30 for only 4 weeks. It has a front loader (unknown make & model) I was wonder approx. how many pounds it will pick up? I was also wondering the same thing about the rear 3point. I have a grader blade with extra weights. It picks up the very slow and only lifts about 5-6 inches off the ground. I can stand on the arms and it lifts me up fine(235 pounds). smooth and fast. Are the extra weights too much? If so how will this effect other implements I buy. Will they be too heavy for the rear hydraulics to operate?
rusty nut
10-08-2004 13:27:50
 Re: pto lifting weight in reply to John-AZ, 10-08-2004 02:17:44
I have a lord loader and it lifts very well,just was moving sand with it today,picks up a full bucket no problem,I've picked up a 500+ pound air compressor out of my truck easily,I've pulled cemented in clothes line poles 3 feet in the ground like it was a tooth pick.I love my loader my tractor is a 51 TO30,Ive moved heavy logs 12 feet long and good size diameter with rear hydraulics with the set of rear forks i have for 3pt hitch
John (UK)
10-08-2004 10:38:26
The rear linkage should pick-up 800 - 1000 lbs depending how close it is to the tractor. If it is only lifting slowly then stops as you say about 5 - 6ins it sounds like low oil pressure,OR lack of oil in the system,(check the dipstick on the round plate) The hydraulic pressure needs to be checked, it should be 2000psi or thereabouts to pick up any weight. If you email me at fergusontractors at hotmail dot com I will send you a "How-to" sheet on troubleshooting the hydraulic system and explain more fully what it could be and what to look for.There is far too much to say about it on here.The loader will lift corrctly if the hydraulics are working at correct pressure, just how much it will lift depends on many things inc. the make.(some lift more than others)
