strange Hydraulics happening
JD/Mo
10-04-2004 12:01:08
When I got my to-30 it had passable hydraulics, nothing to brag about. I changed the oil, although I didn't use the drain proceedure outlined earlier here, and the darn thing got great. The scoop stayed up for nearly half an hour before starting the slow decent. Then just as suddenly I noticed when I shut her down whatever impliment was on would start dropping imediatly. Started to get worried, as I often do when I don't understand something, and then one day I dropped the scoop, "pushed" it into a dirt pile moved forward and, nothing! It wouldn't go up or down. I got off and useing my hands lifted the scoop ( not a hard lift either) and she started up and began to work again.
Well, this week end I was again useing the scoop, and finish mower when my wife called me for lunch, I park Beatrice and wen in for my balony samich. 20 minutes later I looked out and the scoop is still all the way up. I was dumbfounded. Why? Is this acceptable behavior? or did I just get lucky....again?
Sorry for the long "story" just wanted to give the facts.
Thanks for any responce
jim
John (UK)
10-04-2004 12:54:53
 Re: strange Hydraulics happening in reply to JD/Mo, 10-04-2004 12:01:08
Could be just plain out of adjustment on the Control Spring behind the seat. when the implement is lifted there should be no more that .020" end float, any more than this will cause the Control fork to move more than it should do resulting in abnormal behaviour. Something that points to this adjustment is the fact that you said you could lift the implement fairly easily by hand. When you try to lift it by hand you are taking some of the load (the pull) off the top link allowing it to move to its more normal correct position. You may also have some siezing of the Top Link Rocker too.
jd/mo
10-05-2004 06:30:17
 Re: strange Hydraulics happening in reply to John (UK), 10-04-2004 12:54:53
Thanks John, I'll have to re-check the control spring adjustment. I think you sent me the proper proceedure for doing that once before. Just gives me another reason to "play". Thanks again jim
John-AZ
10-08-2004 02:21:23
 Re: strange Hydraulics happening in reply to jd/mo, 10-05-2004 06:30:17
I just purchased a to-30. I am also new to this tractor talk. What are passable hydraulics? And where is this control spring?
10-23-2004 20:56:30
 Re: strange Hydraulics happening in reply to John-AZ, 10-08-2004 02:21:23
The control spring is the large spring in front of the place where the upper link connects, the third arm. That spring should turn easily when arms are up with an implement on, but without more than .20 play...you turn the shaft that runs through the spring to adjust it. I'd get a I@T manual from TSC, or similar, cost about $30.
