Website revamp
Jim W
10-02-2004 07:08:59
Ladies and gents,
I have just redone some of my website to make it easier to navigate, by using a table of contents and changing the front page. However, I have been staring at it so long that I can't tell how it is anymore.
I would appreciate it if anyone who is interested and/or knowledgable about TEAs would take a look and let me know of anything that isn't working or that could be improved. (The primary goal of the site is to provide useful information to people contemplating repairs.)
Thanks,
Jim
Mr Chapp
10-04-2004 19:25:21
 Re: Website revamp in reply to Jim W, 10-02-2004 07:08:59
Hi Jim... Thought you hed a great site to start with, but now it's excellent!!! Lots of work and well done! So much will help me with the to20. I for one appreciate the effort. Thanks, Mike
James, UK
10-03-2004 06:12:45
Great site! Everything worked for me, only comment i would have is that the front page took a while to load - but then I am still on dial-up :(
James, UK
Paul F B
10-02-2004 07:46:22
Jim; Wow, what a great resource! Everything worked fine on your website and it is really well thought out. I can only say THANK YOU. Paul F B
glen (ontario)
10-02-2004 10:24:52
 Re: Website revamp in reply to Paul F B, 10-02-2004 07:46:22
great web site Jim, I use it alot .Got a question for you or any one else that can help .On my Tea20 distributor shaft wobels and cause it to crossfire is the bushing that holds the shaft stedy the one on top plate just under the cap or is there an other one at the base of the distributor and if so where to get a new one ?
John (UK)
10-02-2004 14:31:32
 Re: Website revamp in reply to glen (ontario), 10-02-2004 10:24:52
The bearing that holds the shaft steady is a bush at the bottom, now where you would get a bush for it is another matter. I dont know if the Triumph Sports car uses a similar build distributor or not, if they do you could try the Club they have over there, someone will tell you where it is I am sure. You could change it to electronic ignition if the wear isn't too bad that will make the points no longer required.
John (UK)
10-03-2004 06:23:08
 Re: Website revamp in reply to John (UK), 10-02-2004 14:31:32
I just looked at the actual parts list for the distributor and there is a ball bearing under the advance and retard plate and a bush at the very bottom end.
Jim W
10-02-2004 16:13:07
Nope, I have checked it vs the Triumph and it's quite different.
The shaft has a bushing at the bottom, and a bearing at the top (which is under the plate holding the points). Then the flat metal dust cover over the points has a bit of bushing material in it, and without it you will get more wobble than with it. Jim
James, UK
10-03-2004 06:11:10
 Re: Website revamp in reply to Jim W, 10-02-2004 16:13:07
I don't know about Stateside, but if you visit an industrial bearing stockist over here you can usually get 'Oilite' or similar bronze bushing in stock sizes. Turn down the OD on a lathe, bore the ID to suit, and then press it into your distributor (having first removed the old bush, of course).
Sounds simple, doesn't it? Hmm, I'll have to pluck up courage B4 I do it.
Instructions are in the Ferguson manual, section G16, but the ID you will have to take from your existing shaft.
Don't forget to soak the new bushing in oil before you fit it.
HTH
glen (ontario)
10-03-2004 09:18:24
 Re: Website revamp in reply to James, UK, 10-03-2004 06:11:10
Thanks guys I just got tore down that ball bearing is the main problem
James, UK
10-03-2004 11:04:53
 Re: Website revamp in reply to glen (ontario), 10-03-2004 09:18:24
Good news Glen!
So how long did the tear down take - this info being useful if I get round to mine one day . . . .
