reading seial numbers to-35
John - AZ
09-29-2004 06:49:50
I recently purchased to-35 according to the forged numbers on the transmission and steering houseing where oil is put in. I have check with this site's method of looking at the serial number to determne the year, but this one has different numbers. The plate by the steering wheel reads TO-123493. This site states the number should begin with 14,16,or 17. thxs for the help
steve19438
09-29-2004 09:52:58
 Re: reading seial numbers to-35 in reply to John - AZ, 09-29-2004 06:49:50
even easier way; if you don't have two gear shift levers and if the brake pedals are not together on the right side you don't have a TO-35.
Jeff-oh
09-29-2004 07:04:19
TO-123493 is the serial number an it indicates that you have an 1953 TO-30. not a TO-35.
To verify look at the Left hand side of the engine. Near the bottom a number will be cast.
If it says
"Z129" then diffently a TO-30
if
"Z134" then it is a TO-35. Perhaps the name plate as changed, or it is a TO-30 and the engine was swapped out to the larger TO-35 engine sometime in the past.
John - az
09-29-2004 11:34:58
 Re: reading seial numbers to-35 in reply to Jeff-oh, 09-29-2004 07:04:19
BINGO
engine tag says Z129 which matches the serial # tag of TO-30.
The person I bought it from said it was a TO-35 because the starter was hoziontal and not vertical. I guess he was wrong.
Does this mean the transmission was change due to numbers forged in caseing says TO-3551 or does this number mean nothing at all?
As you can tell this is my first rodeo when it comes to old tractors.
Jeff-oh
09-29-2004 13:04:50
 Re: reading seial numbers to-35 in reply to John - az, 09-29-2004 11:34:58
The TO-3551 on the transmission case is a part number and has nothing to do with the tractor model.
If this is your first Ferguson... Welcome to the board. There are many knowledgeable and friendly folks here.
Most every question has been asked so try a search first, if you don't find what you want just ask. Let us know what you do with your tractor. And consider joining the Ferguson Enthusiasts of North America. A interest group with a good news letter.
Jeff
