What is standard psi and pump gpm for TO30?
jayp
09-27-2004 12:18:02
I received a reply on another post that the TO30 would only lift 750 lbs. What is the specs on a TO30 for the hydraulic system.
Pump GPM
PSI
Ram diameter and stroke
I need to be able to pick up 1000, but I would like to get the specifics before I go any further. By the way, I haven't tried to pick up 1000 lbs, yet. Thanks --Jay
John (UK)
09-28-2004 15:41:40
 Re: What is standard psi and pump gpm for TO30? in reply to jayp, 09-27-2004 12:18:02
I cant find the specs of a TO30 but if its the same as the TE range (most likely will be) flow is about 2.75gpm at 2000 engine rpm. and the pressure is 2000psi. as to lifting 1000lbs you are pushing it, it will depend on how close to the tractor you are with the load too. At the link ends the normal load should not exceed 800lbs or the safety valve will blow, the nearer you get the load to the tractor the more it will lift. If the load is too heavy the safety valve will blow, you should not run the tractor with the safety valve blowing. continuously, if the valve blows...STOP...its too heavy. The 750 lbs quoted to you is for early tractors.
