temp??
JIm Nye
09-26-2004 16:46:29
Just joined the group with a To20 1950 z120 engine
What temp t-stat should be installed?
Also what pressure rad. cap should i have on this engine?
Thanks for help!
Jim
John (UK)
09-28-2004 15:48:01
 Re: temp?? in reply to JIm Nye, 09-26-2004 16:46:29
TO20 thermostat should be:- crack open at 60 deg C. Fully open at 93 deg C. Rad cap should be 4lb.psi
Jim Nye
10-01-2004 05:00:11
 Re: temp?? in reply to John (UK), 09-28-2004 15:48:01
Thanks guys big help!
Now if i could omly get the steering wheel off...
Threaded or splined????Help.One other thing what is the oil capacity of the z120?
John (UK)
10-01-2004 12:03:56
 Re: temp?? in reply to Jim Nye, 10-01-2004 05:00:11
Oh the fun you can have getting that off...lol
its tapered with a woodruff key...Use a puller, load it up then wack the end of the puller and the wheel should jump off. Sump capacity 12 imp. pints
Nickk
09-26-2004 20:42:28
Jim.....Seems that most old TO20's run anywhere
from 160 to 200 degrees. As far as thr radiator cap, I think it's a 4 pound pressure cap.
Have Fun,
Nick
