TO-30 ????
Pete Sigmund
09-25-2004 08:50:42
I recently bought a Ferguson TO-30 or so I was told. The Ser.# is TO-55434. When I look it up in the ser. registry on this web sight the only numbers that comes close to what I have is a model Ford-Ferguson 1941 which starts with ser.#47843. 1942 starts w/ ser.#92363. So I'm assuming I have a Ford Ferguson what?? Can anyone help me w/ this??
Phil(va)
09-26-2004 07:48:07
 Re: TO-30 ???? in reply to Pete Sigmund, 09-25-2004 08:50:42
Billy is correct. You have a TO-20. Oil filter should be inside the pan. The TO-30 filter is on the side of the block. "TO" stands for Tractor Overseas, meaning made in USA instead of Great Britain, and it definitely is a Fergie not a Ford-Fergie.
Pete Sigmund
09-27-2004 19:03:11
 Re: TO-30 ???? in reply to Phil(va), 09-26-2004 07:48:07
Thanks for the info guys, but Phil, I do have an oil filter on the right side of the block. Whats up with that?
Phil(va)
09-30-2004 20:08:00
 Re: TO-30 ???? in reply to Pete Sigmund, 09-27-2004 19:03:11
Does the number on the block begin Z120... or Z129? The latter indicates a TO-30 engine, and the former would be a TO-20 engine. Only thing I can think of off hand is someone replaced the steering box and dash, and therefore you have the serial number from another tractor (if they didn't remove the old serial number plate).
Peter Sigmund
10-02-2004 08:12:00
 Re: TO-30 ? Thanks Phil ! in reply to Phil(va), 09-30-2004 20:08:00
Phil, Thanks for the info I checked my engine numbers and it starts with Z129 so..... I guess I have a TO-30. Thanks again.
Jerry/MT
09-25-2004 20:44:40
Look the serial number up in the Research and Info section of this forum on the left hand side.
billy
09-25-2004 08:59:16
looks like you have a 1951 to-20 same as to-30 just little less horse power.
