radiator cap
Chuck1
09-20-2004 01:06:13
I have a te20 1949 .I was wondering if the rad cap is to be pressurised Mine fits very loose and is I think is the original.Is this system ment to be pressurized
John (UK)
09-25-2004 15:03:32
 Re: radiator cap in reply to Chuck1, 09-20-2004 01:06:13
The system should be pressurised with a 4psi rad cap, the thermostat should crack open at 60 deg.C and be fully open at 99 deg.C. Make sure the thermostat is fitted correctly or it wont drain.
danct
09-20-2004 08:33:40
chuck
cap should be tight,4psi seems to stick in my mind ,if you dont have a temp gauge you should think about doing it ,i did one recently on a te1949 very easy to do and gives peace of mind
good luck danny
