new owner Ferguson 30 -answer to small pto shaft
jayp
09-19-2004 17:27:35
Just bought a Ferguson 30. I"m not real familiar with them just yet. Hope to get some info on this site. I notice my pto has an undersized shaft. It came with an sleeve coupled over the shaft. I hooked the bush hog up to it and made 3 passes before it chewed into pieces. I have been told that a standard shaft is available, but I don"t know what kind of job I"m getting myself into. I"ve also been told to get the clutch for the pto which would eliminate changing shafts and using the sleeve. True? The shaft is pretty short on it. Thanks for any help. Jay
Jeff-oh
09-20-2004 06:35:12
 Re: new owner Ferguson 30 -answer to small pto sha in reply to jayp, 09-19-2004 17:27:35
Jay,
For mowing, you need a Over-riding Clutch (OCR). This is a Safety devise that prevents the mower's inertia from driving the tractor forward. An OCR is required for either spindel size and can also be purchased in 1-1/8 to 1-3/8 to provide the size conversion you want. I have never heard anything good about the slip on sleave converters.
Jeff
Jerry/MT
09-19-2004 18:56:22
You have several choices. You can get a machined 1-1/8" to 1-3/8" adapter( about $15). You can get an over running coupler (ORC) in 1-1/8" to 1-3/8"(about $35-$60). These will need to be removed and the PTO cover put back on for safety reasons when you are not using the PTO. (Not good to gave a spinning PTO shaft exposed where you might get caught on it and to stop the PTO shaft from spinning also disconnects the hydraulics so you can't use the 3 pt hitch.) A shaft replacement kit (shaft, bearing, seal and cover) is about $110, but you will need a 1-3/8" ORC($35-$60) if you will be using any powered equipment like a rotary mower. The inertia if a rotating piece of powered equipment will continue to drive the tractor even with the main clutch disconnected. If you really need to stop, the ORC prevents the inertia of the driven equipment from driving the rear axle. By the way, if you haven't all ready done so, you'll need to invest in a good set of factory manuals (owners, repair/shop, and parts) to understand your machine and be able to work on it. Hope this helps.
ric
09-19-2004 18:27:20
i fought with the small pto shaft for several years untill i broke it running a brush hog.that was the best thing that ever happened. take out the bolts around the pto where it goes into the tractor and just pull it out and slide the new one in its about as simple as that. if you have the front of the tractor lower than the rear you wont loose as much oil.or this could be the time to fill with new oil hope this helps
jayp
09-20-2004 07:24:36
 Re: new owner Ferguson 30 -answer to small pto sha in reply to ric, 09-19-2004 18:27:20
Thanks for all the info. I believe I will run the smaller shaft until it breaks. The ORC sounds like a must-I'll nose around and see who has what. As far as manuals, which ones would you guys recommend? I have found some manuals are not worth carting home.
