Moving snow
Tom-Kenton
09-18-2004 05:01:05
I am "new" to "tractoring", having purchased a To-30 earlier this year to help maintain the five acres at our new home. With winter just around the corner, I am interested in finding out the best way to move snow from our 300 foot long drive. I have a scraper blade and mower, but no other implements. Any suggestions or experiences are greatly appreciated.
Boss Hog
09-20-2004 07:09:15
 Re: Moving snow in reply to Tom-Kenton, 09-18-2004 05:01:05
I've had good luck moving snow with a 35 and a rear mounted blade. It just takes some planning and practice.
For starters, you have to have a place to push the snow to. If your drive is cut out of banks or has bushes on both sides, you won't be able to push snow off the drive too many times.
The first time it snows, you have to push the stuff as far off the road as you can. Don't just push it over far enough to get a car through. Leave yourself enough room to push off plenty more snow. Once the snow sits a few days it becomes much more packed and harder to move.
Also - Plan for drifting. If you push a ridge up on the west side of the drive, high winds from the west will drift it in so deep you'll never get through it. So always turn your blade to plow the snow downwind.
Tire chains will make your tractor work better than one twice it's size. Can't emphasize that enough.
You can pile snow up pretty high by turning your blade around backwards. Shorten up your top link as far as you can. Then as you're backing up, raise the blade. This will lift snow up along with the blade and give you extra weight over the rear wheels.
If you go with a rear mounted blade, I'd suggest getting one designed for a MUCH bigger tractor. Around here you can buy a cheap, lighweight blade for around $200 or so. But your much better off going to a farm equipment dealer and getting one that's made for a 60 to 70 HP tractor.
They're much heavier and will do a much better job than the cheap ones. And they are MUCH better for dirt work and ditching. And you won't tear it up like you will a lightweight blade.
That's my 2 cents worth anyway...
danct
09-19-2004 07:20:12
tom
i have a to30 and have had a Meyers 7 foot plow with left and right turn and up and down on the blade i have a thick rubber edge on the blade to help spare the blacktop ,i have chains on and have the tires loaded ,it will move a pile of snow ,i have a transport bucket on back which i can add more weight Zane Sherman of this site supplied me with the pump, controls and even the hoses for the job if you like being out in the cold ,you will like this setup,the to30 has plenty weight and power you just have to be carefull in the begining good luck
danny
RandyR
09-18-2004 09:11:01
Tom: You could use the blade but with 300 feet to clear and if you get big snowfalls, you'll find the banks on the sides closing in on you as winter goes on. A blower would be the best idea, but they all require you to back up to blow. Something my neck doesn't appreciate. Take a look at this:
Link
A snowblower made for driving ahead. They also make front mount blowers. Maybe for your machine if you ask them.
Paul F B
09-19-2004 10:07:56
 Re: Moving snow in reply to RandyR, 09-18-2004 09:11:01
Randy, couldn't get that address to work, could you post it again? Paul F B
Paul F B
09-19-2004 21:45:53
 Re: Moving snow in reply to Paul F B, 09-19-2004 10:07:56
I found it and for those interested- the URL is below. It sure looks like a nice set-up . Has anyone dealt with this company and what is their reputation? Thanks ,Randy, for your posting of this "new" {to me} type of snowblower. Paul F B
Jim W
09-18-2004 11:56:58
third party image
Depending where you are, you may also be able to find an old V-type single stage that you drive forward with. I have this one on my TEA and have been using it for 3-4 winters now on my ~250 foot driveway. I have been entirely satisfied with this setup, no external hydraulics required.
Jim
Jim W
09-18-2004 11:59:38
 Re: Moving snow in reply to Jim W, 09-18-2004 11:56:58
PS I agree with the above; a blade will not be enough if you get either heavy snowfalls, or if they accumulate. You should also consider a set of chains for your rear tires.
Tom-Kenton
09-18-2004 17:57:45
 Re: Moving snow in reply to Jim W, 09-18-2004 11:59:38
Thanks to all for the replys. I think that I will look in to one of the pull-type rear mounted blowers. And many thanks to everyone that contributes to this board. This is the greatest Ferguson resource on the net!
Bob NY
09-18-2004 18:28:13
 Re: Moving snow in reply to Tom-Kenton, 09-18-2004 17:57:45
Trying to run a snowblower with a tractor that does not have live pto and live hydraulics will be an exercise in frustration.
Jim W
09-19-2004 15:04:26
 Re: Moving snow in reply to Bob NY, 09-18-2004 18:28:13
I'm in that boat with the TEA but I find you get used to it. I grew up in a snowbelt blowing out about 1000 feet, with the same lack of live pto, so have never had the luxury. Of course with the V type the lack of live hydraulics doesn't come into play.
I think having the live pto would be a bonus alright but not mandatory. But more than that I would suggest that an over running coupler is most critical.
Jim
Tom-Kenton
09-19-2004 09:37:21
Thanks, Bob-
Something I didn't think about. Like I said, I'm new. I have a lot to learn.
Tom
