Hydrolic lift
Jack57
09-17-2004 14:57:25
I recently had to disassemble the pto and lift mechanism and when I put it back togther the lift will not work but the pto works ok. Could it be that there is air in the lines or in the lift pump?
Muttonman
09-20-2004 18:00:40
 Re: Hydrolic lift in reply to Jack57, 09-17-2004 14:57:25
I just sent a message to Larry in Ohio. The info I offered him sounds like what you need to fix the problem. Let me know your address if you want the info.
Ray,IN
09-17-2004 21:27:18
Air lock is unlikely since the pump is submerged. I would look for unattached linkage between the quadrant lever and the pump. You can have a major oil leak, remove one of the side inspection covers and use and inspection mirror and flashlight to spot any leaks above the oil level. Take care, fingers and moving parts are not compatable.
