oil filter for a te20
chuck1
09-14-2004 22:11:20
I have a 1949te20 .The other tractors that I have seen have an external oil filter .mine has none.Also my coil is by the rear spark plug and my oil filler is near the front the block has z120on it is this right for a 1949
John (UK)
09-16-2004 11:39:08
 Re: oil filter for a te20 in reply to chuck1, 09-14-2004 22:11:20
TE20 Tractors with the Continental engine were last produced in July 1948 Serial # 48,000 They started fitting the Standard engine in September 1947 they fitted both till middle of 1948
Jeff-oh
09-15-2004 05:21:44
Chuck,
All that you describe is correct for a TE-20. The others you discuss are as Jim indicated are TEA-20 with a different engine. Your oil filter is in the oil pan. It is accessed by removing the large round plate on the bottom of the engine. The replacement filter is available from NAPA and is PN 1107.
Jeff.
Pat-Wa
09-15-2004 13:51:55
 Re: oil filter for a te20 in reply to Jeff-oh, 09-15-2004 05:21:44
Jeff Does the tea-20 (1951) use the same oil filter.If not do you have a napa part # for it.
Thanks
Jeff-oh
09-15-2004 14:55:51
 Re: oil filter for a te20 in reply to Pat-Wa, 09-15-2004 13:51:55
I am sure they do. It is a different filter. The moptor in the TEA is the same standard motor that went in the Triumph Automobile.
Call them, they have good referance books.
Jim W
09-15-2004 04:30:31
Yes, the TE20 had a Continental engine. Later they switched to a Standard engine (the one with the external oil filter) and the name became TEA20.
The Z120 engine on yours is the same as the engine on the American-built TO20.
Jim
