TO 20 Oil Change
Don in VA
09-14-2004 06:45:50
There is a removable plate on the bottom of the oil pan, and there is a drain plug in the plate. Unfortunately,the drain plug does not come out. It turns but stays where it is, so I have to remove the whole plate to drain the oil, which usually results in a mess. Has anyone else run into this? Also, where can I get a replacement plate with a functioning drain plug?
Steve (DE)
09-14-2004 08:39:43
 Re: TO 20 Oil Change in reply to Don in VA, 09-14-2004 06:45:50
The plug screws into a nut which is welded to the upper (inside) of the plate. You probably need to get the plate off and have a quick weld of the nut back into place. Then you should, using some form of rust breaking compound, be able to make the plug work again.
