pto shaft cover?
kev
09-10-2004 06:21:36
Hi guys!, my '51 TEA 2085 has a cover over where the PTO shaft would be sticking out. Cover is rounded, not flat and looks factory.
Has anyone seen this before?, is there a shaft in there or will fluid come pouring out?
I've just got the thing running like a champ so its on to the back end now.
My hydraulics dont seem to be working even though there is brown (not white) fluid on the dipstick)
Im still tryin to teach myself about the workings of the back end on these, so please bear with me.
Does the hyd. pump work off the PTO shaft?, if there is no shaft, does that mean there is no hydraulic action?
Please advise.
Thanks again.
Kev
tex Ferguson
09-12-2004 15:28:14
 Use overrun clutch for shredding in reply to kev, 09-10-2004 06:21:36
Hi Kev and Congrats on the new Ferg!
You may want to operate a shredder with this tractor. Be aware that the PTO is an integral part of the transmission, with its drive gear meshing with the complex that drives the rear wheels. The clutch connects this complex to engine power. When the tractor is moving forward in gear and the PTO is powering a shredder, pressing the clutch obediently disconnects the engine from the transmission. However, power continues to be supplied to the rear wheels from the momentum of the shredder blades via the PTO shaft and the transmission; at this moment, brakes would need to stop not only the (small)forward momentum of the tractor but also the (large)rotational velocity of the shredder blades. I have come very close to destroying my radiator on trees etc from this effect, not to mention mowing down stuff I had not intended to cut. The solution is a $45 extension for the PTO shaft called an overrun clutch. It acts as a big ratchet, isolating the implement and external shaft when they continue to rotate on their own momentum fasster than the internal PTO shaft. This returns control of the internal PTO/transmission assembly to clutch disengagement and throttling down.
Enjoy your new tractor and above all, be safe.
Tex
Jeff-oh
09-10-2004 07:12:03
 Re: pto shaft cover? in reply to kev, 09-10-2004 06:21:36
Kev,
Yes what you are describing is the PTO shaft cover. This is a safety cover for use when the hydraulics are needed but the PTO is not. i.e. the turning PTO is covered to prevent it from grabbing loose clothing etc. If the PTO is required (mowing etc) then this cover is removed. The PTO is in there.
The replacement covers have a "square" on the tip that allows you to put a wrench to it.
No oil will not come pouring out. Take it off and take a look. Also, as you suspected, the hydraulic pump is powered by the PTO shaft. Thus no pump unless the PTO is running. The PTO lever must be engaged AFT. Have the clutch in when you do this.
If the PTO is leaking oil the rear seals are easy to replace if you need to do that.
Glad to hear it's running well.
Jeff
