TE20 - Starts but stops running
Gino
09-05-2004 14:01:07
Hello, I have a TE-20 that has been siting for about 5 monnths. I put fresh gas in, and started the tractor. The tractor will run for about 15-20 seconds and then cuts out. I can then restart, and it will again stop after 10-20 seconds. Any ideas on my problew? Thanks Gino
Jeff-oh
09-07-2004 05:50:44
 Re: TE20 - Starts but stops running in reply to Gino, 09-05-2004 14:01:07
Gino,
I hope this post finds you after you have fixed your problem, I agree with the other posters that it is probably a fuel issue. After sitting for 5 months it is either sediment or varnish but definitely sounds like a fuel problem.
Follow the fuel on down the line from the tank.
1) clean the sediment bowl. Does the fuel re-fill the bowl quickly?
2) Is fuel getting to the carb, remove the drain plug and drain fuel out, Turn on the fuel at the filter and see if you have good strong flow at the drain plug. If not then do the following...
a) Check the fuel flow through the line. Remove the fuel line at the carb. Turn the fuel on does it run freely? If not Remove fuel tube completely and blow clean, also check top of the sediment filter for good flow.
b) Check the carb filter. With fuel line removed, remove the brass elbow at carb intake. Clean the filter screen.
a & b are good things to do anyway. Also, be careful not to cross thread the fuel line nut into the elbow, as both are brass you can strip the threads easily if not lined up right...
3) If good flow at the drain plug but problem persists then it is time to clean the carb. Pull it, get a good varnish cleaner and replace the seals. Take a careful note to the direction of the Venturi as you pull it apart. There is a large end and a small end, note which end goes up.
Hope this helps...
Jeff
danct
09-05-2004 14:51:32
my te20 was like that when i got it ,particles of rust kept clogging up the fuel filters and carb i kept draing the gas and putting fresh in thinking i would finally get all the rust out ,well it never happened ,i finally took the tank off and used the product called POR15 to treat the tank ,no more problems now ,so drain the gas through cheese cloth into a clean 5 gal pail and see how bad it is ,if its bad do yourself a favor and do the job right and you will have one less thing to go wrong
good luck Danny
danct
09-05-2004 14:51:14
good luck Danny
John (UK)
09-05-2004 14:06:54
Have you checked the fuel flow into the carb....is there any fuel in the carb when it stops.?
Gino
09-05-2004 14:38:35
 Re: TE20 - Starts but stops running in reply to John (UK), 09-05-2004 14:06:54
John, I have check the fuel flow into the sediment bowl and ir appears okay. Is there a fuel strainer at the intake of the carb? Thanks, Gino
John (UK)
09-05-2004 15:52:25
 Re: TE20 - Starts but stops running in reply to Gino, 09-05-2004 14:38:35
Sometimes there is one fitted in the elbow in the fuel pipe into the carb, worth checking. Check the flow into the carb from the pipe, then the elbow, if you still have trouble with flow, check the fuel tank cap that the breather hole isn't blocked.
