TEF20 starting with WD40
Robert Kierans
09-05-2004 10:07:48
Before I start my TEF20 I squirt some WD40 into the air hose leading from the air-filter to the manifold. The engine turns much easier doing this, but does this in any way damage the engine? Thanks,
Robert
James, UK
09-05-2004 13:23:28
 Re: TEF20 starting with WD40 in reply to Robert Kierans, 09-05-2004 10:07:48
No, but it won't help solve the cause of the bad starting, either. You do use the decompression lever, don't you?
John (UK)
09-05-2004 14:12:14
 Re: TEF20 starting with WD40 in reply to James, UK, 09-05-2004 13:23:28
Do you use the excess fuel button on the fuel pump? If you do, then do you use the heater and Ki-gas? Really you should not use anything to start it, it will only get worse.
