need help manifold
mark mac
09-04-2004 16:03:20
I have a T030 w/Z129 ,I just replace a bunch of parts on it and rebuilt the carb, Now my manifold gasket has a bad leak . The tractor is running very rough now!
Iam lose power now,is that why iam having all these probelms Now ,please help.....
Jerry/MT
09-04-2004 16:19:34
 Re: need help manifold in reply to mark mac, 09-04-2004 16:03:20
A leakey manifold will cause an overly lean mixture due to some of the airflow bypassing the metering section of the carburetor. And there will be a power loss.This is a bad situation for this engine because it is dependent on some charge cooling via the fuel mixture to cool the engine. Make sure the joint where the carb attaches to the manifold has a good seal. If the leak is where the manifold joins the head, you'll need to either try tightening it down (becareful and don't break a stud) or replace the gasket.
