wiring to-20 need help
jer
09-03-2004 18:30:01
i am having problems trying to figure out how to wire this tractor the diagram that i have does not show a amp gauge . i have a to-30 and i wired it almost to the same except for the ignition when i turn the key on i have a three amp discharge when i hit the starter i charges and i know it shouldn't do that. maybe one of you could spell this out for me step by step your help would greatly be appreciated. thanks again
jer
09-04-2004 20:17:44
 Re: wiring to-20 need help in reply to jer, 09-03-2004 18:30:01
thanks guys for the help i think i got it i also found a wiring diagram today on the web and it shows that i have it wired right thanks again i know i will need more help as i go. thanks again
Gerald J.
09-04-2004 08:33:11
The starter gets wired directly to the battery.
For a positive ground system, the positive terminal of the ammeter goes to the negative battery post, generally at the starter. All electrical loads (ignition, lights, accessories) and the charging line go to the negative ammeter post. All loads have their own switches, but the charging line depends on the cutout or the voltage regulator for automatic disconnect when the engine is not running.
Gerald J.
John (UK)
09-04-2004 08:02:17
I have a wiring diagram for a TO20 6v with an ammeter fitted if you want it....Just mail me at fergusontractors at hotmail dot com
Jerry/MT
09-03-2004 19:18:26
Do you have a TO-30 with a six volt generator system with a positive ground, or has it been converted to 12 v with a negative ground? Regardless, it sounds as if the ammeter is hooked up backward if when you're starting up it shows a positive charging rate. I need more info to give you more help.
Jim W
09-04-2004 06:42:49
 Re: wiring to-20 need help in reply to Jerry/MT, 09-03-2004 19:18:26
Current for the starter should not flow through the ammeter, regardless of polarity.
The ammeter is supposed to be in series between the output of the generator or alternator, and the battery.
Jim
Jerry/MT
09-04-2004 16:30:09
 Re: wiring to-20 need help in reply to Jim W, 09-04-2004 06:42:49
Jim, If I look at the wiring diagram for my TO-30, it seems to be that the ignition current and any field current to the generator will register in the discharge direction on the ammeter when I try to start. Am I misreading the wiring diagram?
Jim W
09-04-2004 16:48:39
 Re: wiring to-20 need help in reply to Jerry/MT, 09-04-2004 16:30:09
I think that's right but I am having trouble imagining it; can you send me the diagram?
jim dot wallace at netscape dot com
(New email for me by the way, for anyone who corresponds).
Once I see it, it will make sense to me.
Thanks,
Jim
Jerry/MT
09-05-2004 21:06:53
 Re: wiring to-20 need help in reply to Jim W, 09-04-2004 16:48:39
I don't have a way to email you the wiring diagra, Jim. No scanner or fax. I'll try to describe.
Battery to starter switch to ammeter to BAT terminal on VR (voltage regulator). Key swich connected to Load terminal on VR and then to ignition primary circuit. Generator field connected to Field on VR. Don't know if this makes sense to you.
jer
09-04-2004 07:23:57
i have a to-20 but i wired it the same as the 30 but like i said when you hit the starter i get a positive charge on the gauge. can you show me step bu step. the wiring diagram i have does not show an ammeter in it so i am puzzled how to run the wiring .
Jerry/MT
09-04-2004 16:13:24
 Re: wiring to-20 need help in reply to jer, 09-04-2004 07:23:57
According to the Ferguson Manual,:
Disconect the black wire with the yellow stripe from the starter switch and also the black wire with the yellow traces fron the bat terminal of the regulator. Tape the ends of this wire.
From the BAT terminal of the regulator, run a 12 gauge wire up to a terminal on the ammeter. From the other terminal of the ammeter run another 12 gauge wire to the hot side of the starter switch.
To determine if the ammeter is installed correctly,start the engine and open the throttle to until a definite delection is noted. If the ammeter reads in the discharge direction , reverse the leads on the ammeter terminals.
Hope this helps.
