Think I screwed up
DavefromMo
08-29-2004 13:57:30
My TO-20 has a 12v conversion with a keyed starter switch. The key turns on the ignition, then the stick shift is used to actuate the starter. Well I lost the key. In a moment of pure genius, I hooked up a toggle switch in place of the key switch. Well now it won't crank at all. Did I cook my voltage regulator or some other component?
Any help much appreciated!
phil(va)
08-31-2004 13:23:55
 Re: Think I screwed up in reply to DavefromMo, 08-29-2004 13:57:30
Keys are available for about $2 several places. Try Stevens in Colshutta, LA. Number on the web.
DavefromMo
08-29-2004 16:45:54
Turns out the Battery just decided to go. Just a coincidence that it went just when I replaced the switch. All seems well now.
txblu
08-30-2004 07:01:18
 Re: Think I screwed up in reply to DavefromMo, 08-29-2004 16:45:54
Those things happen. In your case, your toggle switch was a suitable replacement, and for 2 wires, you can"t go wrong.
Mark
