sway bar
martin christia
08-27-2004 16:33:37
is there a standared length sway bar used on the TO-30
Bill Stanley
08-30-2004 18:39:35
 Re: sway bar in reply to martin christian, 08-27-2004 16:33:37
I think you will find that there two sway bar lengths 31 1/
2” OC and 33 1/8” OC. The correct length must be used or they will break or bend. One of mine snapped the end off while the tractor was sitting still. I am not totally sure but you may also find that the older equipment and generally Ford’s are 31 1/2” and the newer MF’s are 33 1/8”. Caution however since the lower lift arms could have been replaced with newer models (or worse mixed). It is absolutely mandatory that the mounting pin under the trumpet line up with the lower lift arm pin (assuming the lift is to go up and down without bending or breaking something). My under axle brackets have four holes and only one hole is correct. The front hole is the correct hole. Don’t have a clue how the other holes are supposed to be used. If uncertain about alignment ask again and a method of checking can be described.
Boss Hog
08-28-2004 05:43:17
MF used 2 different lengths of lower lift arms. I"m thinking 31" and 33"? - Not really sure.
Before you buy sway bars, I"d suggest measuring the length of your lift arms and buy the same length of sway bar.
marlowe
08-27-2004 20:08:36
all mine are 31 3/4 center of hole to hole and i got 4 laying around or should say that i use
