Tea 20
JED
08-22-2004 04:16:31
Does anyone know the difference in a 12volt & 6 volt TVO engine.If cam shaft is damaged in the con rod seat can it be built up and reground?does anyone know what type of welding rod to use?
John (UK)
08-23-2004 15:50:40
 Re: Tea 20 in reply to JED, 08-22-2004 04:16:31
Basically the only difference in 12v and 6v engines is the hole for the starter, dont understand what you mean about a con-rod seat??? camshaft doesnt run on a con-rod, its in a seperate gallery in the left side of the block. If you have a worn cam on a camshaft it would require welding by a specialist and grinding back to correct profile. Reading it again I think you mean a Push rod seat, well there is a cam follower in there that runs on the camshaft, if that is worn you should replace it, they are available.
John (UK)
08-24-2004 14:01:35
 Re: Tea 20 in reply to John (UK), 08-23-2004 15:50:40
If you cant find anyone who supplies cam followers for your engine see if you can find anyone who supplies parts for the Triumph TR sports car, they had the same engine basically so you may be able to get one through them, we can get then freely over here in UK but probably not as easily in US.
JED
08-24-2004 10:20:55
MENT TO SAY CRANKSHAFT JOURNAL.I WAS HALF CUT WHEN I POSTED FIRST MESSAGE ANY HELP WOULD BE WELCOME.
Jim W
08-22-2004 07:01:02
The hole in the block for the starter is a different size between the 6 and 12 volt models. Don't know about the rest.
Jim
