Model Number
Jack Martin
08-20-2004 13:55:17
I just purchased a 1950? Ferguson. The serial number plate is missing. I don't know how to indentify the model of the tractor. Are there any other numbers on the tractor that will help me.
Thanks
John (UK)
08-21-2004 07:50:52
 Re: Model Number in reply to Jack Martin, 08-20-2004 13:55:17
Is it a TO20 or a TEA20. TE20 has oil filler for engine on left side front of Continental engine TEA has oil filler on left side rear of Standard Motors engine it also has an oil filter on lower left side of engine too. Continental has no external oil filter just a large round plate on oil pan. On a Continental there is a plate on left side of block that will say what the engine is, on a Standard Motors engine the engine number is stamped into the cylinder block between the ignition coil and the oil filler, let us have that number, we may be able to give approximation of the year for you.
Jack Martin
08-21-2004 14:30:36
 Re: Model Number in reply to John (UK), 08-21-2004 07:50:52
I don"t know the diffrence between a TO20 and a TEA20. The oil filter is in the pan. There is a plate on the left side of the engine but can not read any numbers. Evidently I have a TO20 because the oil filler for the engine is on left side front.
Thanks
John (UK)
08-22-2004 05:37:14
 Re: Model Number in reply to Jack Martin, 08-21-2004 14:30:36
Yes, from your description you do have a Continental engine, so it could still be either a TO or a TE. the quick difference is if the gearbox housing is aluminium its a TE (made in England) if its cast iron its a TO...made in Detroit, after that basically the tractor is the same apart from ancilliaries.
Mr Chapp
08-20-2004 14:39:12
I believe I'm correct in saying that a 1950 to20 will have a continental z120 engine. The engine number plate is on the rear, lower left of the engine. Mine is a 1950 to20 and it's true of it. Good luck, have fun!!
Jack Martin
08-21-2004 14:32:55
 Re: Model Number in reply to Mr Chapp, 08-20-2004 14:39:12
Thanks
Jack Martin
08-21-2004 14:32:26
Thanks
