Oil specifications for TED20
Simon
08-20-2004 05:08:16
Hello to all.
Few weeks ago a have asked for the original spark plugs for my TED: Now he is running!
But now I want to do oil changes, engine, hydraulic and gear box.
Has anyone the specifications for the right oil I can use and in additional the right filters?
Thank you very much!
Simon
John (UK)
08-21-2004 07:58:36
 Re: Oil specifications for TED20 in reply to Simon, 08-20-2004 05:08:16
It was always specified for UK SAE40 oil but you can use a multi-grade if the engine is in good order probably 20w/40 is right. The oil filter is Sparex part # S40535 if you cant find a filter post here again.
Jeff-oh
08-20-2004 10:23:23
The hydro-trans. oil is a GL1 90 mineral oil. This is Massey number M1103 and runs $37./5gal.
Shell Oil also make is under the Dentax name and is also aroung $37.00 /5 gal.
TSC has a Ford Transmission oil which is a GL-3 for $35/5gal
and the best price I have found for the GL-1 is at NAPA for $26 and change for a 5 gallon. It is NAPA #65-205.
Robert B, UK
08-20-2004 09:34:54
Simon,
I use straight 40 SAE in the engine and transmision/gearbox/hydraulics as per the manual and have had no problems. I have a sloping filter and you can get the filters from your local Sparex supplier. I f you are in the UK try Holland-Brand, Old 20 etc.
Regards
