TEA-20
Ian A.
08-19-2004 22:18:52
I have a tea-20 and i just replaced the lift cover gasket and when i took off the side covers i noticed that there was a bridge piece on the control forks and when i looked in my manual it says that piece wasnt on those tractors until after 1953 and on the bottom plate wher the pressure tube goes up from the pump there is a place in the plate where high pressure oil can go to an exterior port and where the high pressure tube goes up to the topplate there is a spot milled out for a o-ring I was wondering what year this could be, how long the tea"s were made and if someone could have put newer parts in this tractor,or could it be a different model
it also has a 12 volt system and on the pto there is a overrunning clutch that is factory(it doesnt sick out of the tractor and isnt a different color) and has a standard engine with a zenith carb
will send serial# later
John (UK)
08-21-2004 08:33:44
 Re: TEA-20 in reply to Ian A., 08-19-2004 22:18:52
TEA tractors where manufactured from 1947 till 1956. If its 12v its later than 200,001 (1951) That Stabilizer (bridge piece) has been fitted since # 134,001 (1950) I think we may find that someone has been playing around with this, because the Hydraulic pump was never milled out to accept an "O" ring at that point, the top cover was though at # 330,044 (1953)but only at the ram cylinder mounting, the pump has always had a plain gasket fitted, from what you say the pump has only one take off port on the pump body, if this is the case its an early pump (pre 1949 possibly) so it could have been changed at some time. "O"rings were used instead of gaskets on the pump sidechambers from # 286,543 (1952)The external take off ports on the pump were undercut to accept a sealing washer, are you thinking that is for an "O" ring perhaps? All TE models were the same. Regarding the over-running clutch, never heard of that one nor seen one only tractor I know of with one of those was a Leyland 154 which looked like a Ferguson only smaller. Are you sure about this O/R clutch? seems very odd and if it was a test thing usually they stayed in UK not exported.
Al in BC
08-20-2004 09:14:51
Good day Ian.
Can you give me the code on the Zenith Carb. I will be able to narrow the year down if it is the original carb. No serial plate on the dash behind the steering wheel? Where are you situated ?
Al in BC
Jim W
08-20-2004 12:55:54
 Re: TEA-20 in reply to Al in BC , 08-20-2004 09:14:51
The hydraulic parts from newer TEAs were as you have described, and can be retrofitted onto earlier tractors. I have put a 1955 lift cover and hydraulic pump on my 1951 TEA myself.
No idea on the overrunning clutch question though.
Jim
Ian A.
08-20-2004 20:42:21
 Re: TEA-20 in reply to Jim W, 08-20-2004 12:55:54
it doesnt have the ports on the top cover but it does have one coming out of the left rear of the bottom plate i am situated in ohio near cambrige
Ian A.
08-26-2004 19:20:10
 Re: TEA-20 in reply to Ian A., 08-20-2004 20:42:21
the serial number is TEA190038 and on the rear end near the dipstick is 8 3 1
another thing is that after a while of working with a heavy implement (big back blade) the lift starts bouncing at the top when in neuteral there is very sligt leakdown (few hours)
