TO - 20 Cam timing
Kevin
08-17-2004 20:05:36
Is there an eaiser way to check the cam alignment than pulling the governer housing to see if the marks line up? I don't want to tear down the front half of the tractor if I don't have to.
Mr Chapp
08-18-2004 16:23:02
 Re: TO - 20 Cam timing in reply to Kevin , 08-17-2004 20:05:36
Hi John... Just being honest. If he has the cam specs., lift and duration, a really accurate dial indicator ...on...on...and on. he can check it without removing the cover. As I said before...Sorry to be the bearer of bad news. It's still good luck, have fun!! Otherwise, buy a new tractor for $30,000.
gshadel
08-18-2004 09:39:05
Hey Kevin.. still running rough huh? Wish there was an easier way to check that cam gear, but there ain't that I know of.
If you get in there to check that cam/crank alignment, take a look at how the gears are aligned on the shafts. I had a weird problem on an old VW once where the crank gear had a chewed-up key, and was slipping on the crankshaft. Took me WEEKS to figure out why it was running so crappy! Do you have a nice sharp blue spark on your ignition? And does it stay that way when you speed her up and slow her down? Even with the electronic ignition gismo, it won't help a dirty coil connection or a weak coil. Other than that, and the other ideas from your last post.... don't know... Let us know how it goes.
Mr Chapp
08-18-2004 05:13:35
Hi Kevin...Sad to say that's the easy way. Good luck, have fun!
John (UK)
08-18-2004 11:46:01
 Re: TO - 20 Cam timing in reply to Mr Chapp, 08-18-2004 05:13:35
Mr. Chapp you are being cruel to Kevin...lol
