TE-20 pto
Scott Millar
08-15-2004 08:39:55
I am thinking of buying a topper to go behind my te-20d tractor, is this the best idea for maintaing 10 acres of grassland?
Robert B, UK
08-16-2004 08:44:13
 Re: TE-20 pto in reply to Scott Millar, 08-15-2004 08:39:55
Hi Scott,
Depends a little on how often and type of finish you want. I use a 5 foot finishing mower which I use every couple of weeks with my TED 20. I've set it up so that the weight is on the mowers rear wheels and on the top-link so that the hydraulics will lift and lower automatically as I cover any bumps in the ground. Works a treat. I also have an over-run clutch on the PTO which is recommended.
A friend of mine uses a topper which he drags around on its skids and is very happy with the results. He does not have an over-run clutch (but better brakes!) which may be the reason he gets through PTO converters.
Hope this helps.
