Rear Axle Bearing replacement
Ter
08-12-2004 15:15:30
I am about to replace one of my rear wheel bearings (outer). Before I remove the bearing collar should I mark the spot where the old one was? Is this collar something I will be able to replace myself? When I do get to the bearing is that something I should be able to do myself? Thanks for any comments or advice. Terry
Ter
08-14-2004 05:53:56
 Re: Rear Axle Bearing replacement in reply to Ter, 08-12-2004 15:15:30
Thanks John & Paul for your responses.
John (UK)
08-14-2004 04:22:26
Drill a hole in the collar and split it off with a chisel.You will have to have the bearing pressed off up to 20 plus tons sometimes required, just make sure that the new bearing is knocked down into position as far as it will go and drop the heated collar on and tap that into position to make sure it goes all the way, don't try to put the collar on cold or it will come off again. No need to mark anything it will all drop into place.
Paul in Ms
08-14-2004 02:39:34
The collar you can drill a hole in and then cut it with a chisel. The bearing might have to pressed off. The bearing should have a shoulder on the axle to rest on. The new collar should be heated in the oven say at 400 degrees to expand and will slip on the axle.Let it cool and it will be perfect fit.
