massey to30 three point lift problem
jerrynj
08-10-2004 15:09:18
I had the pump and cylinder piston rings replace. I installed everything back, but the three point lift will not lift. when I remove the inspection covers and push the lift linkage forward the three point lift will lift. I tried adjusting the linkage, but it still will not work. Can anyone help me or point me to a good source.
thanks
jerry
John (UK)
08-11-2004 12:54:21
 Re: massey to30 three point lift problem in reply to jerrynj, 08-10-2004 15:09:18
When you move the control lever does the control fork move inside the housing, if it does does it move the Control Valve far enough to make it lift. It could be the quadrant out of adjustment or too much free play in the Control Spring. If you mail me at fergusontractors at hotmail dot com I will send you a check sheet telling you what to do and what to look for.
