more TO35 questions
gshadel
08-08-2004 14:43:38
I looked at that TO35 that sold at auction yesterday.... sold for $3400... a lot higher than I was willing to pay. Oh well, I guess I'm looking for a real "fixer-upper" in my price range.
Anyway, I noticed the PTO selector had a "engine PTO" and a "ground PTO" selector. What is the difference?
Also say a well beat-up TO-20 at the auction...really well beat-up. Had very milky oil too..... sold for $1000. Thought that was kind of high too for a TO in that poor condition. Maybe my fine looking/running TO20 is worth more than I thought.
Boss Hog
08-10-2004 05:02:52
 Re: more TO35 questions in reply to gshadel, 08-08-2004 14:43:38
The ground PTO sure comes in handy once in a while.
Like if you get the auger of a post hole digger stuck. Jack up one rear wheel, put the tractor in reverse, engage the ground PTO, and back the auger out.
Not that it's ever happened to me, of course. (-:
I've also seen them used that way to turn a plugged up auger backwards.
gshadel
08-09-2004 14:25:24
Thanks for the help guys, I was really wondering what that ground PTO was all about, and why a guy would want to run the PTO off the rear tires.... now I know, makes sense.
Don't worry, I definitely use a O.R.C. with my mowers.
I saw two TO-35's Saturday, both had the serial number starting with a "S", which if I have learned correctly from you guys, means they are "SPECIAL" models, not "DELUXE" models. I could not find any other indication of special or deluxe anywhere else on the tractor. From the input I got last week, I decided if I get a TO-35, I want a Deluxe... unless the price is just too good to pass up. thanks
Jeff-oh
08-09-2004 06:14:28
John is right here.
The ground PTO position is driven in proportion to the ground speed. It is made for above ground implements like side delevery rakes, fertilizers and the like. Thus, the number of turns on a rake is always eaquly per foot traveled down the field. The faster you go the faster it turns. The PTO RPM is Proportional to the wheel speed.
The Engine PTO position is equivelent to what your TO-20 has. Thus the engine speed determines PTO RPM.
Jeff
Randy
08-08-2004 17:42:18
My 35 has that feature too. Ground PTO means the PTO shaft is driven by the turning of the rear wheels. If your not moving, neither is the PTO turning. If that is the only type you have, then you should use an over-running clutch when bushhogging. The energy of the spinning blades has been known to push tractors along even when braking, with disastrous results. The tractor won't stop moving. But engine PTO means the the PTO shaft is coupled to the engine, so a bush hog won't push you around, and you can run equipment while stationary. You can also run the PTO at a faster speed with the tractor in a lower gear and moving slowly. You can't do that with ground PTO.
John (UK)
08-08-2004 19:18:30
 Re: more TO35 questions in reply to Randy, 08-08-2004 17:42:18
Not strictly correct, you need a Dual clutch to stop the mower pushing you along or an over-run clutch if you have a single clutch, you wouldn't use Ground PTO to drive a Bush-Hog because it needs lots of engine power, Ground speed was provided for light power and is driven from the wheel drive, you would use it for a powered side rake or swath turner or maybe a fertiliser broadcaster Most power driven equipment requires you run the PTO at 540 rpm and Ground PTO doesn't run at that, it runs slower and depends on the forward speed of the tractor. Hope you can follow that.
txblu
08-09-2004 06:57:20
 Re: more TO35 questions in reply to John (UK), 08-08-2004 19:18:30
I think it was meant for broadcasting where you had to measure the amount of application and you didn't want any application when you stopped or slowed down; like fertilizer spreading, or weed killing, which, as you say are light loads.
Mark
