id this like a sherman hi-low tranny?
gshadel
08-06-2004 08:36:32
I've been kind-of wanting a hi/lo tranny for my TO-20. Think I would really like the low gear range. I saw this link on ebay, they are calling it a "overdrive". Looks like a sherman or similar hi/lo tranny. What do you guys think?
They don't look to hard to install, have to drill a hole in the bell housing for the shifter, and bolt to the back of the housing. Is that right?
Let me know what you think. thanks
John (UK)
08-06-2004 14:44:31
 Re: id this like a sherman hi-low tranny? in reply to gshadel, 08-06-2004 08:36:32
If they are calling it an "Overdrive" it may be the box that speeds it up not slows it down, you should check exactly what it is.
gshadel
08-10-2004 13:47:21
 Re: id this like a sherman hi-low tranny? in reply to John (UK), 08-06-2004 14:44:31
I emailed the guy selling the tranny and asked him if it was an over/under, or just a overdrive. He said he didn't know what it was.
So, I didn't get it.
Still looking for a Sherman or Hupp.
thanks
MaxH
08-06-2004 12:01:12
Greetings,
This appears to be a Hupp mfg. I have one on my TO 30. It gives you an over/direct/under. I have more info if you like. Email me if you desire more data.
Max
gshadel
08-06-2004 12:20:44
 Re: id this like a sherman hi-low tranny? in reply to MaxH, 08-06-2004 12:01:12
Max, can't seem to get the email thing to work for me. Think you could adequately pull a rototiller using the low range on your Hupp tranny? That's one of the reasons I'm looking for one.
Also, is it as easy to install as I described above?
Lastly, think I could still get parts for it if needed..
thanks, George
MaxH
08-06-2004 12:45:00
 Re: id this like a sherman hi-low tranny? in reply to gshadel, 08-06-2004 12:20:44
George,
I bought my tractor and the Hupp was already installed, so I am not sure about installation. However I do not think it will be dificult after splitting the tractor, It will need a holed drilled on the right side of the housing. I think that in 1st with low range it will be suitable to rototill with. I will look up the info on the Hupp and send it on.
Max
MaxH
08-06-2004 13:05:30
 Re: id this like a sherman hi-low tranny? in reply to MaxH, 08-06-2004 12:45:00
George, Here is a link that will give you more info on the Hupp as well as others.
gshadel
08-08-2004 14:34:38
 Re: id this like a sherman hi-low tranny? in reply to MaxH, 08-06-2004 13:05:30
Thanks Max, awesome web site. Your right, that is a Hupp unit! I was watching some vintage tractor pulling Saturday, looked like fun. Thought I might like to try that, but I would definitely need a lower gear range on my TO-20 for that.... one more reason to get a unit like this.\
thanks for the help
