Sorry folks - I kind of hijacked that thread!! I must admit that I am in favour of unleaded, for historical and other reasons. When I had the head rebuilt the company did say (when I asked them to make sure I had seats in for unleaded) that it was not necessary as the engine was pre-lead anyway. The same company also added 'self-lubricating' valve guides when the head was rebuilt. Yes, you are quite right that there is a scavenging system for oil vapour from the rocker cover to the inlet manifold, and yes it will help lubricate the inlet valve guides 'downhill' of the oil in the rocker cover. John (UK) I did manage to sort out the control valve setting in the end - I followed the instructions on the Holland-Brand website, and also looked carefully at the geometry of the plough and top link. My feeling is that the plough is a bodge of a 3 furrow to a two furrow, and is Cat II to Cat I converted - none too well. Upshot is that the top link angle was incorrect, causing pressure on the top link mechanism when the plough was lifted out of the ground, leading to the valve being operated to 'lift' the plough - consequently when the plough was lifted out of the ground, it wouldn't drop it again. Simple really, it just took a while to figure it out. Thanks all.
