oil leaking under distributor
gshadel
08-04-2004 09:38:28
Posts look a little slow today, so thought I would ask your thoughts on this question that has been nagging me for a several weeks now.
Coming off a Z-120 engine rebuild, my oil pressure runs 35psi - hot, cold, idle, full speed, don't matter. I'm sure the relief valve is getting quite a workout. When I got her running again, I noticed I have a slight oil leak around the base of the distributor, where the distributor is clamped down on the block. Not bad, just enough leave a wet oil trail down the side of my new paint job. I never noticed a leak there before, but it would have been hard to tell before. I'm running straight 30 wt oil until I think she is broke-in good, then I'm thinking of switching to 15W40... same oil I use in my truck. I have lots of it, buy it by the pail.
I don't recall a gasket right there, and didn't have any leftover gaskets with my rebuild kit. Think this leak is related to my oil pressure?
Think I need a gasket there?
I know multiweight oil debate can get heated so let me phrase the question like this... How do you think 15W40 oil would impact my pressure situation compared to the straight 30? Little less pressure, same, more?
As always appreciate your thoughts
thanks
Gregg/Ohio
08-04-2004 20:50:18
 Re: oil leaking under distributor in reply to gshadel, 08-04-2004 09:38:28
"I'm thinking of switching to 15W40... same oil I use in my truck." I run 15W40 in my TO-35 (Z134 engine) with no problems at all,Very Clean under valve cover,Very Good oil pressure. I am sure the Ferguson Factory would agree if they could see the results today! Gregg
gshadel
08-05-2004 12:05:57
 Re: oil leaking under distributor in reply to Gregg/Ohio, 08-04-2004 20:50:18
Gregg, thanks for the reply. I see quite a few Ohio boys in these tractor posts. I live in Morrow County. Where you at?
thanks George
Gregg/Ohio
08-07-2004 20:05:52
 Re: oil leaking under distributor in reply to gshadel, 08-05-2004 12:05:57
Hello George, I am in Montgomery County,Oh. Just a few miles north of Dayton where My Trusty TO-35 helps take care of 12 acres of Suburban landscape.
Jerry/MT
08-04-2004 14:32:41
My TO-30 has an "O" ring between the distributor clamp and the block. The parts manual lists a part # 180 550 M1 for the "O" ring.
The relief valve is supposed to be set for 30 psi so your 35 psi, if correct and not a gauge error, is a little high. Your relief valve spring might be a little bit stiff. I have a renanufactured engine in mine and it reads a consistent 27 psi. Hope this helps.
John (UK)
08-04-2004 11:28:25
I looked in the parts list and I can't see a gasket that goes there at all. Maybe a rubber "O" ring around the base of the distributor where it goes into the block would cure the leak, don't use one that too thick though. Over here in UK we always used 40W oil so your choice of oil seems to be ok. I would think if anything you would get a little more pressure, but by the time it's done some work it will all settle down, it surely won't do it any harm anyway.
