TVO TO DIESEL
DANO
08-02-2004 05:09:15
IS IT POSSIBLE TO PUT A DIESEL ENGINE INTO A TVO TRACTOR.
John (UK)
08-02-2004 12:20:17
 Re: TVO TO DIESEL in reply to DANO, 08-02-2004 05:09:15
Yes you can put a diesel engine in what was a TVO tractor but you dont have much choice on engines that will fit. To be safe you need a TE tractor with a serial number higher than 325,001 (1953) these have a stronger diff and back end although if you drive it properley and don"t keep shocking the drive the older ones are ok.
James, UK
08-02-2004 09:01:33
Yes, but watch out you don"t break your half shafts - the shafts on the TEF series were tougher I think to cope with the extra torque.
A lot of the P3 engined TE/TO series were conversions from TVO as diesel was then cheaper.
Nowadays it is as cheap (or expensive) to run on TVO as it is diesel - or at least it is in the UK :(
HTH
