TO35 Loader
Garry
03-17-2000 10:12:20
This is probably a dumb question, but its got me stumped. I have what I think is a Henry loader mounted on a TO35. The hydraulic pump is front mounted. My question is, where the heck do i check the hydraulic oil level and where do I add oil if needed?
Big Dean
03-17-2000 11:26:11
 Re: TO35 Loader in reply to Garry, 03-17-2000 10:12:20
most loaders that I have dealt with have the reservoir in the loader frame they either have dipstick or a check plug on the uprihgt part of the loader frame.
Garry
03-17-2000 11:40:24
 Re: Re: TO35 Loader in reply to Big Dean, 03-17-2000 11:26:11
I've got neither one of those. The only thing I see is a breather port that comes off the frame near the top. I took the top of the breather port off, but there is no dispstick or anything. Any ideas? Maybe I'm missing a part?
Tim (UT)
03-21-2000 10:27:08
 Re: Re: Re: TO35 Loader in reply to Garry, 03-17-2000 11:40:24
Yup - the breather cap is the place. As for if you have enough fluid in it, see if:
1. The loader arms will go all the way up
2. The cylinder(s) for the bucket will open all the way.
My loader on my Ford 8N leaks quite a bit at the pump. I only use it to load my manure spreader every so often, so I just fill it with enough hydraulic fluid to raise the loader above the spreader side.
Tim
