Massey Ferguson 165 PTO lifting problems
Rich
07-29-2004 07:09:06
I think I have two problems here, first the PTO. It seems to turn fine until I hook up an attachment then it turns the attachment(brush hog) real slow. Second problem is when I hook up attachment (brush hog)to the 3pt. hitch it will not lift it, but without an attachment it seems to lift fine. any suggestions greatly appreciated as I'm no mechanic.
Thomas
07-29-2004 10:19:25
 Re: Massey Ferguson 165 PTO lifting problems in reply to Rich, 07-29-2004 07:09:06
The hydraulic pump is driven by a shaft running along the bottom of the transmission, from a drop down gear at the front. The PTO drives from the back of the pump, through the engagement gears. If your lift is also slow it points to a problem before the pump drive, probably PTO clutch engagement. Probably clutch adjustment will cure it, otherwise a new clutch.
