TO-20 carb
kurt
03-16-2000 21:42:06
just rebuilt the carb on my to-20 it works ok but gas leaks out of the jet on the bottom of the carb when the engine isnt running. i didnt have any parts left over when i was done so i'm stumped on this one
stan
03-20-2000 19:34:32
 Re: TO-20 carb in reply to kurt, 03-16-2000 21:42:06
had the same problem after rebuild. kept tinkering with the float level until i got it right. i know the directions with kit says parallel but i to adj.it beyond
Clarence Carhill
03-17-2000 19:14:08
Kurt... The reason its leaking is because your needle and seat isn't holding and it should. Several things to check.
1- Your float may be leaking. Did you shake it to see if it was empty? Did it look good? You might not have your float set at the proper level. When holding the carb upside down the float needs to set parallel to the cast iron base. Be carefull not to put presure on the needle and seat while bending.
2- Does your needle have a vinton (rubber looking) tip. If it does you might have to twist it real lightly with your fingers. When you changed the seat down in the base were you careful not to make any burrs with your screwdriver? If the needle is all brass a very light tap with a very small hammer will sometimes seat it.
SandyB@TN
03-17-2000 03:38:01
Kurt,
All of them will do this if you don't turn the gas off at the tank. With gravity feed, there's always pressure on the system. When I stop for any reason, I just turn the gas off. Solves the problem.
Sandy
