TO35 head rebuild failure (so far) Please Help
Max
07-27-2004 08:34:57
Hi Everybody,
I have a question for the obviously intelligent responders here. I was asked to rebuild a TO35 for a friend which had weak compression on one cylinder. The first three had around 110 psi, but #4 was at 60. I added oil to each cylinder, and that bumped all four up by about 5psi. A-Ha, I thought - easy valve regrind/replacement (if necessary.)
Well, I started the process, and my friend said "Since you have it open, let's put in new valves for all cylinders." Never should have listened to him, but I did. In the process I reused those little buttons on the tops of the valve stems - which according to other posts on this forum may not be necessary any more. Don't know if that made a difference or not. I also discovered that the original valves in the weak cylinder didn't look all that bad. Neither did the seats, which gave me pause for a second. Not sure if that's indicative of something else, or just a red herring.
Buttoned it back up, torqued the head up to 30, then 60, and on the first pass up to 90 I stripped a head nut - one of the old crusty ones outside the valve cover. I replaced the stud and nut after waiting a few weeks for the parts, and left the whole thing torqued to 84 for an initial test. I gapped the valves at .015 and now my compression is between 45 and 65 on all four - although the original cylinder is now one of the high values. That's my first question: what's the proper torque for the Z134 engine?
This also brings up my second question: What am I missing that caused such a precipitous drop on compression?
I lapped the valves, but did not actually regrind the seats. However, I did get a nice matte ring on the valves and the seats also looked appropriately polished. Haven't had a problem with this in the past, using an identical technique.
I didn't blow any bubbles (a la a warped head leaking coolant) and all of the valve springs appeared to have good tension. I didn't actually check the compression resistance of the springs, however.
I did leave it torqued to 60 for about 3 weeks without any coolant in the engine and missing one head stud, but I don't think that would be enough to allow any corrosion of the head or block, which would then allow air to sneak past the gasket. I did not check this, however.
Those are about the only things I can think of which would cause such a dramatic drop in the compression, although I'm not necessarily the brightest bulb on the christmas tree at times.
So, I'm flummoxed. Any and all thoughts are greatly appreciated.
Thank you for your time,
Max
gshadel
07-27-2004 13:10:31
 Re: TO35 head rebuild failure (so far) Please Hel in reply to Max, 07-27-2004 08:34:57
My work has been on Z-120 engines, I don't know the torque on a Z-134 head bolts/nuts. I'm assuming you followed the correct torque sequence on the head. If you don't have a manual, maybe someone can post a picture ,or email you the sequence for a Z-134. If it is the same as a Z-120 or 129, I can email it to you. Leaving it sit a few weeks the way you described should not be a problem. Torquing the wrong sequence might cause problems though.
Everything you described sounds like it makes good sense. Re-using the valve stem caps was a good move, assuming the replacement valves had the same stem length as the old ones.
Running the engine a bit, and rechecking compression sounds like a good idea to me too. How does it run? This may sound stupid, but are you sure your getting good compression numbers? Maybe the compression is so good now that you blew your guage! Got to keep your humor with these things, not worth doing if it isn't fun.
I have heard that lapping valves was more along the lines of "fine-tuning" or "finishing" the mating of the seat and valve, not as good as grinding the seat to correct a significant difference in the mating surface. I have long complained about poor quality replacement parts. I would not be shocked to hear your replacement valves had different face angles, or different stem lengths than the originals. I don't think any amount of lapping would compensate for something like that.
I personally hate messing with valves, seems like unless you do a whole rebuild with guides, seats, valves, springs, the works... it is hard to get a good job. If the compression doesn't build after running it, and you decide to tear it back open again, tell your friend the head needs to go to a shop to check for warping and grind the seats. Around here, that is about $50 at the machine shop + the cost for your beer. Let us know your next move, and how things turn out. Good Luck
Russ
07-27-2004 17:24:32
 Re: Re: TO35 head rebuild failure (so far) Please in reply to gshadel, 07-27-2004 13:10:31
Lo pression; I would definitely run the rig for a couple 30 minute cycles with an external 20 fan for enhanced cooling. Retake your compression
on all cylinders warm. If the tester has a synthetic or rubber tip lightly coat it with mineral oil and see if the readout level improves.
Borrow a thread in compression tester if necessary. No luck, take the the head to a reputable machinist along with two 30 packs of pass out beer. When others stop by to shoot the bull about machining products he can pass out a few beers. If he finds a mildly warped head from earlier overworked/overheated/etc. he can mill it flat or you can locate a replacement head. A new or decent engine should have 14.7 x (the compression ratio) = say 70 psi per cylinder
or whatever the tractor repair manual gives for a spec. Good luck in your troubleshooting and repair efforts.
Jerry/MT
07-27-2004 18:17:32
 Re: Re: Re: TO35 head rebuild failure (so far) Pl in reply to Russ, 07-27-2004 17:24:32
Compression ratio is the ratio of the cylinder volume at BDC to the volume at TDC,. VBDC/VTDC.It isn't a pressure ratio. Compression testing should be done with the throttle wide open and the tube between the aircleaner and the carburetor removed.
James, UK
07-27-2004 10:14:14
When I rebuilt the head on my TED 20-85, I also did all the work you describe - including valve seat replacement/recutting etc. etc.
I also was disappointed at the initial apparent lack of compression - but I ran the old girl anyway. A few months later the starter switch was playing up, so I decided to start her on the handle - lined it all up and gave my usual half-hearted pull (which would normally have spun it over nicely).
I nearly did myself an injury - running the engine had bedded in the valves nicely, and boy, was there compression now!!
Moral: Don't panic yet, run it for a while and see what happens after it has all bedded in.
As to torque values, sorry I can't help.
txblu
07-27-2004 09:58:37
Well, the oil test told you that you had top end problems, not bottom end.
The contact test told you that you had good valve seating.
The springs wouldn't die overnight if weak spring pressure was suspected as they were good enough for your initial readings.
But if your replacement valves STEMS WERE TOO LONG, the springs could not be as springy.
Since you said what you did and did what you did, with a final reading where all cylinders are perculating evenly it says you got everything pretty much where it belongs. So what's wrong is affecting all cylinders equally, and a full set of soft springs (via longer stems) would surely do that.
Don't know what else it could be including head gasket torque/leaking.
Check your valve stem length.
Mark
