exhaust pipe to manifold leak
Jeff-oh
07-26-2004 05:32:13
Model: TE-20, 1948
Engine: C. Z-120
I have an exhaust gas leak in the connection between the manifold and the exhaust pipe. It is one of the origional designs. The clamp is a two piece, concaved centerline and bolts on either side... standard clamp.
I tried wrapping a soda can around the joint then re-attaching the clamp. This may have made things a little better but is still has a stron steady jet of exhaust gas flowing.
Are ther other techniques to seal this fitting? Tricks to apply the aluminum can? I just wrapped it and let the clamp crimp it down. Are there etter wrapping materials? etc. Thanks for you input.
Gene Stevens OH - Tx
08-19-2004 15:15:13
 Re: exhaust pipe to manifold leak in reply to Jeff-oh, 07-26-2004 05:32:13
Jeff, would you send me the Position Control drawings? I am not able to see the demisions on those you posted. Thanks Gene formally of Springfield and now in TX
Crem
07-27-2004 19:50:25
I also use furnace cement on my exhaust connection. One thing to check is that the front end of the muffler has the supporting bracket attached. I have seen a lot of those pipes held on by the manifold and the rear bracket. This allows the front end to swing and loosen the joint up. I actually made a bracket that attached to the bell housing bolt to hold the pipe secure.
Jeff-oh
07-27-2004 05:03:15
Thanks, all
I have to try one of these Ideas in a couple of weeks when I'll have some more time to mess with it.
Jeff
Dale in WV
07-26-2004 17:44:40
As I recall I had to fabricate a sort of gasket using a double thickness of window screen, cut like a donut, and a healthy helping of muffler cement. No more puffing!!
Jerry/MT
07-26-2004 16:13:02
Hi Jeff,
There is a fiberglass rope that is used to seal woodstoves. I think it comes in various diameters. You might try that. Of course you can consult with some of your GEAE seal people. they can probably come up with some exotic seal design for you!
Will
07-26-2004 10:22:03
The exhaust clamp is likely on upside down. The exhaust pipe is flared at the end and should seal if the clamp is properly installed.
Mike Ferguson
07-26-2004 14:19:50
 Re: Re: exhaust pipe to manifold leak in reply to Will, 07-26-2004 10:22:03
I got some asbestos rope from my hardware store. I think it is used to seal stovepipe. I wraped it around the gap before instaling the clamp. Has worked for 4 years.
gshadel
07-26-2004 09:26:59
Jeff, don't know how your exhaust manifold looks on the end. It it looks anything like mine did, it would benefit from cleaning, filling with exhaust cement, grinding and sanding to reestablish a good smooth angled face to seal against the exhaust pipe. A little cement to "glue" the pipe to the manifold might help too.
If I recall, those clamps will go on either way, but the faces are slightly diferent angles, only one way is the right way.
hope this helps.
danct
07-26-2004 07:58:23
jeff
i use furnace cement on mine ,just follow the directions ,i used the Hercules brand last time lasted for ages
good luck Danny
JD/Mo
07-26-2004 07:44:53
Hi Jeff, in my younger day's of driving junkers, I use to get a muffler/tail pipe bandage at the parts store. Of course this wouldn't be much help if your talking about a show tractor. It was a fiberglass bandage with an epoxy that cemented the whole thing together. Worked sometimes and sometimes it didn't, but was cheaper than replacment cost's on the budget I had at the time.
Hope this helps.....I'm kinda more into making things works than making them look good. Jim
txblu
07-26-2004 07:31:46
That's what I use.
