Throttle lever can't keep RPM's up
Chris
07-21-2004 18:23:34
My throttle lever keeps slipping up the whole time i'm on my tractor. I try to ignor it until the rpm's get so low it starts acting like it's going to cut off. I've been looking for the part that has the teeth or grooves or whatever you call it, but have yet to find anything. Do they sell this part or do you have to rig up something?
Al in BC
07-22-2004 21:01:57
 Re: Throttle lever can't keep RPM's up in reply to Chris, 07-21-2004 18:23:34
Chris.
I have a TEA 20-85. I believe this will solve your problem. Go to the back of the dash and locate the throttle shaft. Pressing against the back of the dash is a friction washer, spring and clamping device. Loosen the clamping device and set more pressure. You might need more than two hands. If you have problems contact me on the back burner @ alsherhys at shaw dot com. no spaces
Al in BC
Chris
07-22-2004 12:31:54
I have a TE-20.
gshadel
07-22-2004 11:30:20
I just went thru the exact same problem on my TO-20. On my particular model, the friction rings Jeff is talking about were made of rubber instead of cork. They looked as though they had been worn thin, and squished a bit. I made new ones out of cork gasket material I had laying around the garage. My cork was rather thin, I ended-up making 4 rings, gluing two together to make 2 thicker rings. I also had to really compress-down that spring clamp on the throttle rod,on the backside of the dash, that puts tension on those friction rings. That was a pain in the hind end, almost needed 3 hands to do it, and you have to rotate it just right so it doesn't bind into the battery when you move the throttle. That throttle is rock solid now!
good luck!
Jeff-oh
07-22-2004 05:33:04
There are two cork friction disks that keep the throttle in position and are easily replaced.
You can make you own out of cork gasket material if you wish. The disks go on either side of a washer and under the mounting bracket that holds the throttle under the dash. the dimensions would match the washer. For a MF-65 the dimensions are 1 7/8" diameter with a 9/16 hole in the middle and made of 1/8" thick cork.
YOurs would be similar. The I.D. would match the throttle shaft diameter and the O.D. would match the washer. Or if you still have some of the origional use it for dimensions.
Jeff
Boss Hog
07-22-2004 04:13:25
What model tractor is it? Different tractors have different setups for holding the throttle position.
steveormary
07-22-2004 10:44:17
 Re: Re: Throttle lever can't keep RPM's up in reply to Boss Hog, 07-22-2004 04:13:25
Chris;
I think it is the nature of the beasts. Ours seemed to do that from new. Replaced the gasket material but didnt seem to help much. Mabe needs a gov. adjustment.
steve
John (UK)
07-22-2004 13:24:40
 Re: Re: Re: Throttle lever can't keep RPM's up in reply to steveormary, 07-22-2004 10:44:17
To steveormary, if the lever isnt moving out of the position you have fixed it in, it could be the governor that needs adjustment...but if the lever moves without you touching it, the friction needs adjusting or repairing on the throttl shaft under the dash panel. If you need help to set up the governor linkage mail me at fergusontractors at hotmail dot com
chris
07-22-2004 18:18:26
 Re: Re: Re: Re: Throttle lever can't keep RPM's up in reply to John (UK), 07-22-2004 13:24:40
Yeah, the whole throttle lever moves. I have tried to just hold it in position, but my arm gets tired.
~C.C.~
John (UK)
07-23-2004 10:42:35
 Re: Re: Re: Re: Re: Throttle lever can't keep RPM' in reply to chris, 07-22-2004 18:18:26
You need to adjust the spring and plate at the back of the dash panel,on the log rod that runs behind the air filter, compress the spring. It could possibly be that the friction material is worn away or highly polished, either way it would require replacing. It would be possible to make these yourself.
steveormary
07-24-2004 09:16:02
 Re: Re: Re: Re: Re: Re: Throttle lever can't keep in reply to John (UK), 07-23-2004 10:42:35
John (UK)
Thanks for the reply. I dont have to worry about it any more. Rretired,sold out and moved south into New Mexico.
steveormary
John (UK)
07-25-2004 09:49:05
 Re: Re: Re: Re: Re: Re: Re: Throttle lever can't k in reply to steveormary, 07-24-2004 09:16:02
Don't you think that was a bit drastic, just because the throttle lever was slipping?...lol Best of luck and health in your retirement.
steveormary
07-25-2004 20:35:24
 Re: Re: Re: Re: Re: Re: Re: Re: Throttle lever can in reply to John (UK), 07-25-2004 09:49:05
John(UK)
Ya,it was a little drastic and if I had to do it over I wouldnt sell out and move. I would just retire. Health is the reason I had to retire.
steve
