TO-30 carb problems?
jt1
07-20-2004 06:00:03
I am having trouble with our to-30. We have put a carb rebuild kit on it, and set the screws at 1 turn out. The tractor will start running badly and the only way it will run is with the choke on. We have pulled off the carb after it ran badly and a couple of times the carb and the air inlet tube were filled with gas. We didn't have any major problems until we put the rebuild kit in it. Any help would be appreciated.
gshadel
07-20-2004 09:25:45
 Re: TO-30 carb problems? in reply to jt1, 07-20-2004 06:00:03
I rebuilt my TO-20 carb last Winter. After the rebuild, the float needle no longer provided 100% fuel shut-off. If I don't close the fuel bowl within ~30 minutes of turning off the engine, the carb floods. I've pulled my carb twice to re-check the float gap, even installed another rebuild kit needle and seat... same problem. Sounds like you may be having the same problem. Because of this new development, I also discovered my old fuel bowl was leaking by. Had to buy 2 new fuel bowls because the 1st new bowl leaked-by also. Got a good one now, finally. Never had this problem before. The old needle was all metal, the new needle has a rubber tip, don't know if that is the reason.
The float and mixture settings in my rebuild kit, and my manual were different. I used the manual settings - idle mix (small screw) was 7/8 turn open, the power adjust (big screw) was 1 1/4 open. When I got things running, I found those settings were perfect.
This will sound stupid, but when I reassembled my carb, I had the choke spring and flapper bass-ackwards so the choke was normally closed, instead of normally open. I realized my error when I went to re-install the carb.... a minor set back that I had to correct.
Check that float gap again, make sure your fuel bowl shut-off works, then use it. Try the mixture settings above. Hopefully some of this will help. Sorry this is so long... I just went through exactly the same thing ! Good luck !
jt1
07-23-2004 08:10:52
 Re: Re: TO-30 carb problems? in reply to gshadel, 07-20-2004 09:25:45
We ran into the problem of it flooding if we didn't turn off the fuel so we started doing that. What do you mean when you say that you had problems with the flaot bowl leaking by? We have our choke in so that the choke flapper falls towrds the float. thanks
Mr Chapp
07-20-2004 08:45:43
Check the float setting carefully. By pulling the choke you're simply cutting off the air supply. Also check the flow to the carb. and with the bowl off. Good luck, have fun!!
