Piston Oil Ring on TE20
Ray A
07-19-2004 18:17:51
I bought an engine overhaul kit from YT for my TE20. In a box containing Engine Sleeve Assembly the ring kit says to place the three piece oil ring (waffle and two rings) in the third slot down on the piston. I have always found the three piece set to go on the bottom slot. Has anyone encountered this before? I called Alpha Tractor Service and they said this is the way the rings go the piston in this set.
Mr Chapp
07-20-2004 08:52:06
 Re: Piston Oil Ring on TE20 in reply to Ray A, 07-19-2004 18:17:51
Ray, there should only be one ring land in which the oil rings will fit. the compression rings should have much narrower groves. Good luck, have fun!! If there is a lower ring that is narrow it's probably what I've known as a wiper ring.
