TO#8 - Position Control
Jeff-oh
07-19-2004 06:10:52
Scott,
When I met you at the Warren, Ohio show over the 4th of July weekend you were showing me your "origional" styled position control you manufactured. I had thought it looked familar... This past weekend was my first chance to play with the old TE-20. Low and behold, there it was, an origional bracket like the one you had reproduced. The main difference is that it has a square headed screw in the right side... not real sure what that was for.
This bracket was not hooked up the space between the brackets were too tight to slip the "modern" top link clevis into the bracket. I had always thought it was for stay bars when using a drawbar.
Also, I cannot figure out how the system worked to provide position control. I know you showed it working but what was your set-up?
Jeff
