can't get engine speed up- need some ideas
gshadel
07-18-2004 11:55:10
After rebuilding engine and installing everything, I can't seem to get the engine speed up above about 1200 rpms. I went through and adjusted all the linkages according to the manual. Still no better. I can push the throttle linkage by hand to get more RPMS but the govenor pushes back, soon as I let go of the linkage the engine slows down again.
What am I missing here?
I tried adjusting the govenor screw on the gov. housing too. Didn't seem to help, Had to screw it back in some to get the govenor reacting correctly again when I put a load on the engine.
Spent a whole morning trying to figure it out with no success. Need some ideas.
thanks
Jerry/MT
07-18-2004 12:22:57
 Re: can't get engine speed up- need some ideas in reply to gshadel, 07-18-2004 11:55:10
I had a similar problem except I couldn't get over 1500 rpm. You'll have to go through the proceedure for adjusting the governor linkages that you'll find in the shop manual and have a whole bunch of patience. A I recall, you have to perform the adjustments per the proceedure and if you change anything, you have to repeat the process. I recall the process to be very sensitive to the adjustment of the u bolt that clamps on the throttle lever rod. Hope this is of some help to you.
