TO30 fenders
Sol
07-14-2004 14:21:56
I am prepping my to30 to paint and I have noticed that the fender skins have some rivets and some bolts holding them to the framework. Do you guys remove the skins completely to paint or leave the rivets in?
danct
07-15-2004 08:19:12
 Re: TO30 fenders in reply to Sol, 07-14-2004 14:21:56
sol i just did a to30 but it had no rivets only bolts .i had to soak the bolts good with PB blaster as i didnt want to strip or break anything ,also i found some were slightly diffent in length so i made a drawing and numbered where every thing was ,also my fenders were slightly bent and had quite a spring when i unbolted the last bolts be aware
good luck
Mr Chapp
07-15-2004 07:11:37
Sol...I'm planing on removing all sheet metal and fender brackets on mine this winter simply because there is a substantial amount of rust on the bolts & rivets, as well as some dents I want to repair. Good luck, have fun!!
sol
07-15-2004 07:22:25
 Re: Re: TO30 fenders in reply to Mr Chapp, 07-15-2004 07:11:37
I wonder what a good way to get the rivets out would be?
Mr Chapp
07-15-2004 07:49:37
 Re: Re: Re: TO30 fenders in reply to sol, 07-15-2004 07:22:25
Grind the head as flat as possible and drive through with a punch.
Terry
07-14-2004 18:44:26
I left mine assembled, when I sanded & painted mine.
