fuel bowl question
gshadel
07-14-2004 05:01:07
The fuel bowl I removed from my TO-20 was the "9N" style with the round knob to open 2 turns, then open all the way for the "reserve". Had the screen on top that sticks in the tank, the fuel outlet was a flare fitting to attach to a steel fuel line running down to the carb.
Bought a new fuel bowl off this web site, got it today, it is a different style, I would call it a "Farmall" style. No screen, and the main issue is the fuel outlet is a 1/8" pipe thread only. I need to find an adapter to hook-up my steel fuel line (don't know if I can find such a thing), or install a hose barb and hose, and rig a way to convert the hose back to a flare fitting to go into my carb. strainer elbow. Don't want to do that.
Which style fuel bowl was the original? Did I get the wrong one? Going on 2 weeks with broken tractor because of this simple thing. thanks
gshadel
07-16-2004 05:02:40
 Re: fuel bowl question in reply to gshadel, 07-14-2004 05:01:07
Dudes, thanks for your comments. It is obvious to me this new fuel bowl I just got in the mail isn't the right thing.
The nearest MF dealer is at least a 100 mile round trip, there is a New Holland dealer about a mile from here.... guess where I went after work yesterday.
Turns out the fuel bowl N.H. sell for the NAA is exactly the same as the bowl I took - off my TO-20, and sounds like what you guys said have on your TO's. I paid their outrageous price and got one. Installed it last night, good quality part, worked great. I'll be brush hogging this weekend.
thanks.
Jerry/MT
07-14-2004 12:13:02
Per the Ferguson Parts Manual, the original fuel filter assembly for the TO-20, -30, is part # 180 141 M91. It has the stacked plate fliter in the top, not the screen. The bowl for this filter is part # 14 659 A for the TO-20 (1-1/32" x 2-3/16") but the part # 1 001 514 M1 was also used (2 x 1-5/16").
The fuel filter assembly with the screen on the top was used in the TE-20 and the TEA-20(80) and -20(85) and is part # 825 705 M91. Hope this helps.
Ray,IN
07-14-2004 20:39:26
 Re: Re: fuel bowl question in reply to Jerry/MT, 07-14-2004 12:13:02
Not all! My 1953 TO30 has the screen filter with the two different height inlets and the knob that holds 1 gallon in reserve by turning it two turns open for usual operation. Dad bought this tractor new when I was 11. I know as fact it is the original sediment bowl fuel filter. Any MF dealer carrys them, some farm stores, and most tractor salvage yards can order them from Sparex.
Jerry/MT
07-15-2004 11:57:29
 Re: Re: Re: fuel bowl question in reply to Ray,IN, 07-14-2004 20:39:26
Hi Ray, My '54 TO-30 has the stacked disc filter and the two little inlet pipes set at different heights to give you a reserve. I'll bet that all these fuel filter assemblies (sediment bowls) are interchangeable between tractor models. I'm sure that on the assembly line, they used them interchangeably. My comments were based on what the Ferguson Parts Manual says.
